spratin with only 750 psi
Old Feb 25, 2003 | 09:59 AM
94z'sson's Avatar
i was racin my camaro on sunday but i was only gettin 750 psi and i was wondering if i would get more power if the psi was around 950-1000
Old Feb 25, 2003 | 11:11 AM
95greendragon's Avatar
Yes your bottle pressure is extremly important and you WILL notice when its right and when it's not. My bottle heater was well worth it!
Old Feb 25, 2003 | 11:27 AM
94z'sson's Avatar
which heater do you recommend?
Old Feb 25, 2003 | 11:36 AM
This is the one I have:
http://jcwhitney.com/item.jhtml?ITEMID=43688&BQ=sc
This is the cheapest I've seen it. Mine works great, heats my 10lb up in about 10 minutes and my 15lb up in about 20 min. Just make sure you wire it up so it will not run with your key off in case you forget about it.
Old Feb 25, 2003 | 12:04 PM
94z'sson's Avatar
thanks
Old Feb 25, 2003 | 01:16 PM
COMNBYU's Avatar
94ZSSON-
this is just a suggestion, but if your on a budget, like so many of us are, heres what i did-
went to Target and bought a DC to AC convertor for 24.95. then flew off to Wally World and picked up a heating pad for 9.95.
the convertor plugs into your cigg lighter adpater and the actual unit fits right under your seat (its not that big- about 4"x 6" in size). the heating pad plugs into the convertor and wraps aound your bottle.
it works very well and will have a 10lb bottle warm to the touch in about 20 minutes or so. the particular pad i got has 3 different settings so once itsw warmed up real good you can turn it down some to keep it there.
as you can see its quite a bit less than 110 bucks and is as efficient as can be.
jon
Old Feb 25, 2003 | 01:18 PM
Not a bad idea at all.
Old Feb 25, 2003 | 01:37 PM
94z'sson's Avatar
my dad and i just finished ours out of a pair of electric heater sox we showed both together and voila it is very ghetto but it works
KYWes
Jun 14, 2022 06:52 AM
13qtr
Oct 28, 2016 08:11 PM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
canuck94z28
Aug 19, 2015 05:50 PM
