spratin with only 750 psi
This is the one I have:
http://jcwhitney.com/item.jhtml?ITEMID=43688&BQ=sc
This is the cheapest I've seen it. Mine works great, heats my 10lb up in about 10 minutes and my 15lb up in about 20 min. Just make sure you wire it up so it will not run with your key off in case you forget about it.
94ZSSON-
this is just a suggestion, but if your on a budget, like so many of us are, heres what i did-
went to Target and bought a DC to AC convertor for 24.95. then flew off to Wally World and picked up a heating pad for 9.95.
the convertor plugs into your cigg lighter adpater and the actual unit fits right under your seat (its not that big- about 4"x 6" in size). the heating pad plugs into the convertor and wraps aound your bottle.
it works very well and will have a 10lb bottle warm to the touch in about 20 minutes or so. the particular pad i got has 3 different settings so once itsw warmed up real good you can turn it down some to keep it there.
as you can see its quite a bit less than 110 bucks and is as efficient as can be.
jon
jon
