Spark Plugs and Nitrous
Old Dec 31, 2003 | 12:58 AM
TaylnStorm's Avatar
Question Spark Plugs and Nitrous
I have about 66500 miles on my car and am going to change the spark plugs (which are stock) very soon. However, I plan to run a wet kit sometime in the future, which is whenever I have money (while being a poor college kid). My friend tells me I can't run plats with nitrous, but I dont want to put copper ones in right now because I'll just have to change them again. Would I be ok juicing the car with plats or should I hold off on changing them till the juice. I only ask because it is a real bitch to change damn LT1 plugs. Thanks for the *** backwards motor GM
Old Dec 31, 2003 | 01:47 AM
97SS0594's Avatar
DO NOT JUICE ON PLATINUMS!!!!!! i still have mine in but i dont spray often and there getting changed very very soon. i guess the platinums run hotter and if you spray it can blow the tip off the spark plug, leaving that little peice of metal to do all sorts of stuff to your cylinder walls!!
Old Dec 31, 2003 | 02:12 AM
DrewHMS97SS's Avatar
nitrous also causes an increase in temp inside the chamber, so the hotter plugs are a no go unless you want to melt the piston tops. copper plugs are fine for daily use, you dont think we are spraying 24/7 do you? run some ngk tr55 plugs and go. i know how you feel on the plug changing btw, try headers too
Old Jan 7, 2004 | 05:37 PM
Hawk's Avatar
Tr55's are stock heat range plugs, for nitrous go with the NGK TR6 plugs, they are colder then stock.
Brian
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
