SES after install of NX kit
Old Oct 28, 2002 | 10:20 AM
MonoxideChild's Avatar
Well, it's a 94 z28 M6
We installed the kit and then he has a SES light. He does not have a aftermarket ignition , so we had to tap the Tach wire on the drivers side (near the fuel rail) would this cause the SEs due to Lower voltage?
thanks!
Old Oct 28, 2002 | 03:34 PM
gb95zconv's Avatar
Re: SES after install of NX kit
thanks!
That shouldnt cause an ses light....I did the same thing except I cam right off the pin at the pcm. Did you try disconnecting the battery to reset the pcm to see if it goes away ? Double check the areas you worked in to see if you knocked any connectors or vacume lines loose.
Old Oct 28, 2002 | 03:48 PM
n/M we found a bad AC leak. =)
hope this is it!
Old Oct 28, 2002 | 04:14 PM
nope. :P I'll update later. =D
LeftoverChinese
Jan 14, 2024 03:03 PM
Jan 23, 2015 01:13 PM
CARiD
Jan 14, 2015 04:00 AM
Dec 4, 2014 11:56 AM
