Safety First!
Old Jun 9, 2007 | 03:34 PM
bkpliskin's Avatar
Safety First!
what is most likely to break while spraying a 100 shot?
what should be the first few things i should think about in terms of safety other than a fuel pressure safety switch?
Old Jun 9, 2007 | 03:53 PM
2000GTP's Avatar
With a 100 shot on all the proper safety gear, you shouldn't break anything. Along with the FPSS, definitely a window switch should be incorporated into your setup as well. Check out this sticky as it gives some good info on the safety gear: http://web.camaross.com/forums/showthread.php?t=496116
RUENUF
Mar 13, 2016 03:37 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
Daluchman1974
Sep 11, 2015 06:12 AM
4586
Aug 18, 2015 07:08 AM
