rpm switch
Old Jul 8, 2007 | 07:18 PM
northdakota93z28's Avatar
Angry rpm switch
i just got my rpm switch in and i tested it with a test light and i drove it out side my house and it worked perfect, i have the rpm switch connected to my nitrous master switch and i wired up my zex to the rpm switch and when i got it all hooked up i hit the switch and it revs to 1500 rpms, it didnot do that when i first hooked it up and tested it with the light, so i am stumped, the only thing i could think of is that my master switch is hooked up to a orange wire (drivers side under the kick panel), mabey it has something to do with that, any help would be great.
Old Jul 8, 2007 | 07:48 PM
it about has to be something with that orange wire like i am taking to much away from it and it is doing something with the fuel or timeing so i need to figure out what that wire is.
Old Jul 8, 2007 | 09:44 PM
anyone?
Old Jul 8, 2007 | 10:18 PM
LiENUS's Avatar
Your engine itself actually revs to 1500 rpm without you touching the pedal?
Old Jul 8, 2007 | 10:22 PM
ya, it is when the soleniods r not grounded it runs some power throw the zex box to my tps sensor so i dont know what zex expects?? something might be wrong or u need to ground it all the time? but how could u run a window switch? i am about fed up with zex!!!
Old Jul 8, 2007 | 10:43 PM
i will try to call zex in the morning. we will c how it goes.
Old Jul 8, 2007 | 11:16 PM
LiENUS's Avatar
The tps sensor getting voltage can't cause the rpms to jump, are you sure its not spraying the nitrous?
Old Jul 8, 2007 | 11:20 PM
y not i think at wot it is getting like 8 volts and if 3 volts r getting threw it will raise the rpms.
Old Jul 8, 2007 | 11:21 PM
ya i dont even have my nitrous lines connected
Old Jul 8, 2007 | 11:22 PM
LiENUS's Avatar
How will it raise the rpms? your car isn't getting enough air to feed it for those rpms.
Old Jul 8, 2007 | 11:27 PM
well it is i jumped the box right to the battery and when i did it reved to 1500
Old Jul 8, 2007 | 11:29 PM
i dont know i give up
Old Jul 8, 2007 | 11:30 PM
LiENUS's Avatar
I would expect perhaps a small jump in rpms from extra voltage at the tps but not 1500 rpms sounds like something is way miswired, give them a call hopefully theyl'l know better what the systems doing.
Old Jul 8, 2007 | 11:37 PM
i dont give up i did some more testing and found out it is for sure the box and i will call zex in the morning
Old Jul 8, 2007 | 11:38 PM
it is not miss wired i ran the kit for a few months. it is something to do with the zex box or the way they made the box.
