Question hooking up the Bottle Heater
Old Dec 13, 2003 | 07:03 AM
Ataririder's Avatar
Lightbulb Question hooking up the Bottle Heater
I hooked the power wire upto my AMP in the trunk. I didn't want to run a whole new wire to the battery. So I combined it where the power wire for the amp is. Is that bad? I don't feeling like blowing up the amp or popping fuses. Has anyone else hooked up their heater like this? TIA
Old Dec 13, 2003 | 09:06 AM
Josh-'04 GTO's Avatar
What size power wire do you have running from the battery to the hatch area?
If you're running #8 or thicker for your amp, the bottle heater will be fine. But if you've got a very strong amp, you'll probably want to turn off the stereo when you use the bottle heater.
Old Dec 15, 2003 | 09:38 AM
slow's Avatar
I do that all the time in installs, just make sure the system has a a large enough power wire for both to be on.
I always install systems with overkill, so that is not a problem for the installs i do.
Ryan.
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
