Is purging a necessity?
Old Jan 31, 2005 | 10:16 AM
whatsup's Avatar
Getting ready to hook up the wet kit and someone asked about where I was purging to. I hadn't planned on it.....do you have to have a purge? I know it gets the air out of the line but other than running rich for a second is there any other negitive affects from not purging?
Old Jan 31, 2005 | 11:28 AM
wlz28's Avatar
Re: Is purging a necessity?
when I ran my car without a purge it would just stumble for a split sec when you first hit it. rich I guess. Some people say you can activate your system and just slap the pedal to the floor real fast a couple times and be good, but that sounded like a bad idea to me. and besides nothing gets everyones attention better than comin up to the line and purgin a white cloud of smoke outa your car. Thats the main reason I got mine. looks SWEET
Old Feb 2, 2005 | 11:38 PM
"White Knight"'s Avatar
you do it so it hits hard and doesn't stumble......it doesn't seem as impressive when you hit the red button and you have to wait for the power...you want it right then
Old Feb 3, 2005 | 12:36 AM
25THRSS's Avatar
Not only does it purge air from the lines, it is also used as a means of fine tuning bottle pressure.
Old Feb 4, 2005 | 04:53 PM
huffin Z's Avatar
25th hit it right on the nose!
i would like to add that when I had nitrous on my car, I always purged it to bring the nitrous up to the solenoids, so you wouldn't have to wait on it!
Old Feb 5, 2005 | 09:31 AM
whatsup's Avatar
This sounds like a good point that I was not aware of. Could someone expand on this some? I thought you just hooked up the bottle, purged the line to get the nitrous up to the solenoid and away you go.
Old Feb 5, 2005 | 11:21 AM
25THRSS's Avatar
It's simple. Ideally you want a little more bottle pressure than you need. Lets say you want to spray with 900 psi bottle pressure. If you set the bottle exactly at 900, by the time you purged, some pressure would have been lost in the line and out through the purge and you would have to reheat the bottle. You'll never have the exact amount of bottle pressure anyways just from a heater, so purging is the only way to fine tune it. Set it a little higher than you want, and purge the pressure down until you have reached the desired psi.
Old Feb 5, 2005 | 01:37 PM
LT1Squirrel's Avatar
also, it blows out any crap/debri that may have gotten into the lines
Old Feb 6, 2005 | 09:19 AM
whatsup's Avatar
thanks!!
Quickss96
Jan 29, 2016 05:56 PM
350350
14
Aug 11, 2015 12:03 PM
Strick
May 26, 2015 11:41 AM
SergheiS
Apr 26, 2015 08:15 PM
NXz28
N2O Tech
Jul 16, 2003 07:31 PM
