problems with My NX, please read
I recently changed my opti, because the car was missing and running like A$$. When I took the intake elbow off the silencer/resonator tube was filled with gas. It went all over me
. I am thinking the fuel selenoid is bad maybe ? I've only used the nitrous once since I had it installed, so I doubt it was just from that one time. I haven't been able to see if the fuel selenoid was stuck open because I haven't put the car totally back together from the opti install yet.
Anyone have any thoughts on this, or any samiliar experiences ?
. I am thinking the fuel selenoid is bad maybe ? I've only used the nitrous once since I had it installed, so I doubt it was just from that one time. I haven't been able to see if the fuel selenoid was stuck open because I haven't put the car totally back together from the opti install yet. Anyone have any thoughts on this, or any samiliar experiences ?
It soungs like the silinod may be leaking if you had alot of fuel in there with very little use. Also make sure your nozzle is not spraying down toward that opening.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Greg
95 Z28 conv M6
NX 150 progressive,
z28projects4ever
9
Jul 16, 2002 07:48 PM
