problems
I have a 350 with the Edlebrock Performer RPM 100 - 250 kit (100 shot installed) and a 1/2 fuel system (line, pump, regulator, filter) and when I hit the button I only get fuel and no nitrous. When I test the kit with the car off or at idle i get nitrous to fog up out of the carb but when I race under full load I don't. We checked the fuel pressure and it is about 8 psi when we hit the button and can't figure out why it won't work. If anyone can give me some things to look for that would be great.
Thanks, Aaron
Thanks, Aaron
Re: problems
Thanks, Aaron
Thanks, Aaron
2.) Check your wiring make sure all the grounds are good and what not(use a voltmeter if you have to.)
3.) Check for any kinks in the line.
4.) Make sure your bottle is full
Re: problems
Just a thought...If your using a fuel pressure safety switch(which you should be)...check the setting to make sure that when your driving under acceleration(when you describe your nitrous solenoid isn't working), that your fuel pressure isn't dipping just slightly below where you have your fuel pressure safety switch set, causing the nitrous solenoid not to function...
Re: problems
Magenta_Hearts
Mar 25, 2015 10:24 AM
