problem with tnt plate kit
Old Oct 12, 2004 | 08:25 AM
1994TransAm's Avatar
hey guys,
i have a gas blaster kit from TNT and i cant get my TB on with the plate because the IAC passage hits the WP!!
what can i do... the plate makes the IAC useless so i donno?
Old Oct 12, 2004 | 05:15 PM
383lt1's Avatar
Re: problem with tnt plate kit
i had the same problem with the kit. we had to grind down the water pump housing a little bit
Old Oct 12, 2004 | 07:35 PM
Mr_Bond's Avatar
Once you grind it you won't be able to see it. Also make sure none of the clamp on the wp hose a hitting the tb also.
oldschool
Feb 9, 2016 09:21 PM
Jan 23, 2015 01:13 PM
alphaauto
Jan 23, 2015 07:42 AM
Queens94z28
Dec 20, 2014 09:11 PM
Z28STYLE23
Aug 17, 2002 07:40 PM
