ported heads/stock cam/fully forged bottom end??
ported heads/stock cam/fully forged bottom end. is it safe to spray a 300 shot through that??? naturaly i will be upgrading the fuel system. I know people are going to say why a stock cam? i am looking for sleeper mode here.
300 woohoo
WOW 300 is a lot for a small block dont care whats done to it
Not at all sayin it cant be done Just would creep up on it
I would start with some really good fuel say 114 -116 race fuel no airport ****. And some really cold plugs NGK 9 if not a 10
Spark plugs are a hell of a lot cheaper than pistons
Good Luck let us know how it goes.
I'm not 100% sure if this is the route i am going to go, but if so the car wouldn't see lower than 110 fuel. I might wait until next winter to do the engine rebuild and finish setting up the chassis/rear end this winter.
A rule of thumb I often hear is not to exceed 50% of the engine output before nitrous. For example, if an engine makes 400 horsepower, then a 200 shot is a reasonable amount of nitrous to run on it all other variables (bottom end, fuel delivery, etc) are all up to par.
Originally posted by InjectedSS
stock lt1 dude
lol j/k no i sprayed that on an LT1, well not stock of course... shes got a lil some something inside there
stock lt1 dude
bother to share it with us??
Originally posted by TMDZ28
what kind of some something inside you have there brother??
either way, let's just say this, my ****'s built to do it
when i was running a stock bottom end though, i made sure to have my NGK TR6 plugs gapped at like 0.35, run straight 100 unleaded gas, and i ran about 6* of timing retard...
just play it safe guy's, do what i said above and you can DEFINATELY spray AT LEAST a 200shot on a stock bottom end... DO NOT do it like ALL THE TIME, but you could get away with doing it like 2 or so passes down the track to get a cool timeslip
also what i like to do is CHANGE MY OIL before i go to the track when i knew i was going to be spraying big on a stock bottom end... I still do it now cause it's better to be safe than sorry
not being a dik but i just don't really like telling anyone. people that i know read this board and then word will get out what's under the hood and that ='s me getting no race's
please share your knowledge
i understand.... good luck with your races man...
what about autolite 104's?? i heard they are okay for small shots....i'm running 104s gapped at 0.30, 75 shots, with no timing retard. i thought 150 shot is ok without timing retard
