Pics of my custom N20 brackets!
finally got my CNC machined brackets done for my 15lb bottle. i will post pics when its mounted.
http://community.webshots.com/album/123091599ypcGaU/1
Originally posted by Amped96
WOW...those are NICE. The only downside is now you have to clean up your bottle.
thats what EVERYONE says. I have had that bottle for years.I am getting it anodized black. Does NOS still make 15lb bottles that you can buy seperately? thanks for the great comments
You might want to rotate the bottle so the discharge is facing down, and to the rear at a 45deg angle. The siphon tube bends forward in the same direction as the discharge (opposite from the handle). When you put the bottle in cross-ways instead of front-to-back, you run the risk of the siphon tube being uncovered when the bottle starts to get low, and the liquid nitrous is being pushed to the rear by the acceleration of the car.
nice work with the bracket
I noticed in your pics that your spray nozzle is mounted at an angle on the bellows. Does that tip straighten out inside there or are you spraying into the side of the TB?
Heavy
Heavy
ddr698
Jan 31, 2015 10:58 AM
