which one better NX kit or TNT kit??
Old Mar 18, 2004 | 12:59 PM
  #16
262guy?'s Avatar
I love my NX kit. 13.29@102.03 with bolt on's in a 4.3l s-10. 100 shot.
Old Mar 22, 2004 | 06:43 PM
  #17
Sunsceamer's Avatar
I have TNT and it was fat rich. I had it dynoed and the rwhp ratings match up real close on my car. In the sffba TnT is the kit of choice.
Yes 100 is 100 but there is a reason for 2 nozzles but I wont tell.LoL By the way I feel I have one of the best bolt on spray cars for around. I went 11.47 @122 spraying and 13.2 on motor. didnt spray till the 60 and the clutch slipped bad shifting from 2nd to 3rd and 3rd to 4th on drag radial, 3725 race wieght. w/ TNT150 nitrous and 100 fuel jets. this combo puts my air fuel at 11.0 to 1.
Old Mar 22, 2004 | 10:47 PM
  #18
formula383's Avatar
I have had a NX kit, I liked it pretty well. I just got my new TNT F2 kit. I don't know that there would be much performance difference in the two but I just prefer the plate setup.
Old Mar 23, 2004 | 01:10 AM
  #19
unTAmedLS1's Avatar
I wonder what would happenif u jetted both n20 jets at 150 but one fuel at 150 and one at 100
Old Mar 24, 2004 | 01:02 PM
  #20
Dan Parker '96's Avatar
I run a TNT kit on my '96 Vette (LT4/Hotcam/A4).
With 50psi fuel, 75hp fuel jets (dual .018), 100hp nitrous jets (dual .039) and 950psi bottle pressure it netted an extra 122RWHP. AFR was 12.0:1
The TNT plate setup is good but you'll have to purchase a few extra items. The bolts that come with the kit are too short and you'll need some 90degree AN adapters to fit the nozzles on the plate for hood clearance and so the lines don't look like crap.
Also, you'll have to enlarge and shape the IAC hole in the plate to match up with the TB. It's way too small initially.
Here's a couple links with pics... you'll have to scroll down a bit..
http://forums.corvetteforum.com/zero...tid=1544495307
http://forums.corvetteforum.com/zerothread?id=613727
Old Mar 24, 2004 | 02:05 PM
  #21
DrewHMS97SS's Avatar
tnt nozzels are a little better in my opinion.
also the plate setup is much better for even nitrous distribution between the cylinders. i have seen nx kit motors taken apart, and the rear cylinders always show signs of leaning out. when the nozzels are mounted behind the tb, its a straight shot into the intake, so the rear cylinders lean out like in a elbow setup.
Old Mar 24, 2004 | 04:38 PM
  #22
unTAmedLS1's Avatar
I think Im gonna do 150 jets on one side and 100s on the other for a 125 shot
Old Mar 24, 2004 | 04:47 PM
  #23
the 150 jets are good measure. just be sure that you tune it well; especially if you are running on a stock bottom end. I would also reccomend the use of a progressive controller, it will lighten the hit on your drive train.
lt1xondeck
Mar 18, 2016 07:22 PM
karpetcm
Aug 14, 2015 03:02 PM
RX Speed Works
Jul 24, 2015 02:25 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
Jlo
Jul 22, 2015 05:00 PM
