ok 1st time
Old Jan 28, 2007 | 08:35 AM
93camarochrisz28's Avatar
ok 1st time
ok i have a 93 lt1 and i am pushing about 350 360 rwhp and i want around 410 420 and i was going to ask you guys the best set up for my car
Old Jan 28, 2007 | 09:16 AM
Ray@NitroDaves's Avatar
A single nozzle wet kit would be the easiest to install/tune for your car....it can supply 35-150 extra HP.
Our Jan. special would give you everything needed to run a safe/consistent/legal kit
Old Jan 28, 2007 | 12:01 PM
i was looking at this but i dont know what i would need to make a kit and all that new to n20
Old Jan 28, 2007 | 12:14 PM
2000GTP's Avatar
The single nozzle kit basically contains everything for a basic nitrous setup. However, to spray safely and consistently, I would also spend the extra money and purchase the NX Gen X2 upgrade package which will include your fuel pressure safety switch, blowdown tube, bottle heater, and purge valve. Also, you should look into one-step colder, copper conductor, spark plugs such as the NGK TR-6s or the Autolite 104s and a window switch. If you purchase the Mallory 685 Hyfire ignition box, it contains both a built in window switch and timing retard function, as well as having the benefit of a box that gives your ignition a hotter spark. Also, view this sticky to get an idea of what these different accessories do that I mentioned.
http://web.camaross.com/forums/showthread.php?t=496116
Old Jan 28, 2007 | 12:21 PM
wow this is alot to take in but i will do it and thanks for the help so far and more will help
Old Jan 28, 2007 | 05:43 PM
Moshbmx1's Avatar
Its easier then you think to take in. I was new to nitrous last year and learned a lot through this forum in a short amount of time. Search through old threads to get more info. Its all about running a safe set-up. Do your research and you will be just fine. Trust me, any quesion you may have will most likely be able to be answred on this forum.
Old Jan 28, 2007 | 05:52 PM
HarrisSpeedWorks's Avatar
Take a look at our Single Nozzle Sudden Impact wet kit:
http://www.harrisspeed.com/shop/prod...cat=364&page=1
I suggest running a colder set of spark plugs, along with a bottle heater & RPM Window switch for a complete safe set up. Let me know if you have any questions.
Thanks,
Matt
Old Jan 29, 2007 | 07:33 PM
thanks for all the help guys
Feffman
Oct 9, 2015 05:42 AM
CaRParts102
Dec 6, 2014 08:45 AM
Timberwolf
Jul 20, 2002 08:45 AM
JasonD
Jul 15, 2002 02:17 PM
