When putting my system together, I used ALL NX stuff. EFI kit, Gen X-2, "Maximizer" controller, and NX TPS activation switch.
I've spent a few weeks getting the system wired, and I haven't even used it yet. Everything is wired as per NX's wiring diagram. Tonight I was testing my purge, and while doing so, my NX TPS switch activated. For those unfamiliar with the NX TPS switch, it taps into the factory TPS wire at the computer. When the TPS gets to 4.0 volts, it activates the NX TPS switch. On my system, it then sends a signal to the "Maximizer". This thing activated tonigth with the car NOT RUNNING ,and the throttle closed! This thing worked "as advertised" a few days ago when I was adjusting it.
I figured maybe it was getting a false signal from the TPS/computer, so I unhooked the activation wire. The LED stayed lit, and the switch stayed on! It now comes on as soon as the system is armed, and it starts running the program in the "Maximizer".
I'm certain this isn't a wiring problem. It activates with just the hot and ground hooked up...Even with the relay unhooked!
I planned on spraying for the first time tomorrow, but now it looks like I'll have to make motor passes only.
Anyone else have one of theses TPS switches? Anyone else has a problem with them?
Frank
Frank
Quote:
Yes....I have proper voltage (4.5V) at the white wire. The white wire is irrelivant, though...This thing activates when the white wire is unhooked. It activates as soon as the arm switch is turned on with just the red and black wires hooked up.Originally Posted by Mr_Bond
Did you check the volts in white wire on the TPS to see what it says at close throtle when the light is on? Did you adjust the screw?
I've turned the adjustment screw to it's extremes. This thig was working when I first put it on. This happened suddenly...I hadn't touched any adjustments.
NX told me to send it back, and they'd replace it. The only thing I've got to pay is shipping.
Frank
Sounds to me like the relay is bad and is stuck closed. Check all of your relays to be sure. Man that sucks. I was hoping to hear of a 10 sec pass this past weekend.
Matt
Matt
why not use the tps on the maximizer?
Quote:
Matt
LOL...Um, Matt...This thing activated with the relays unplugged. I tried swapping my relay with my H2O pump relay first, and then tried it with NO relays. The only wires hooked up were the hot (directly from swiched ON), and ground.Originally Posted by Nostang 96z
Sounds to me like the relay is bad and is stuck closed. Check all of your relays to be sure. Man that sucks. I was hoping to hear of a 10 sec pass this past weekend.Matt
We'll try for that 10 second pass in a few weeks
Hmmm...10SCNDZ???? Frank
Quote:
Older style maximizer without internal TPS.Originally Posted by DrewHMS97SS
Frank
that suxRegistered User
You need to ditch that thing and get a manual swithc like mine. After that failure I'd be really scared to run that switch. If it were to fail...kaboom. You should go to Nucar and grab a mechanical swithc and try it out this weekend
Good Luck
Matt
Good Luck
Matt
Quote:
Good Luck
Matt
I've got the micro switch that came with the kit, but I can't figure out a way to mount it on my Holley T-Body Originally Posted by Nostang 96z
Good Luck
Matt
Frank
Bring it by my house tonight if you want and I'll fab up a bracket to get it to work. I wanna see that thing on the hit.
Matt
Matt
Quote:
Frank
Mount it under the gas paddle where it activates when you floor it.Originally Posted by 12SCNDZ
Frank
i never thought of putting it in the car. good idea.
Same thing just happened to me. Switch was fine for the first few runs, then I noticed like a surging effect. Looked at the TPS switch and it was glowing red when the key was turned ON/Accy - Nitrous system not armed.
Unplugged the wire to the TPS Sensor, and it was still lit! I played around with the ****, and got it to activate the system, but that red light is pissing me off. Before I send it back, I am going to isolate it from the system and see if it works. Mabey it is somehow feeding back + power somewhere in the system???
Unplugged the wire to the TPS Sensor, and it was still lit! I played around with the ****, and got it to activate the system, but that red light is pissing me off. Before I send it back, I am going to isolate it from the system and see if it works. Mabey it is somehow feeding back + power somewhere in the system???Quote:
The LED on mine stayed lit, and it was starting to run the program in my maximizer as soon as the system was armed!Originally Posted by formulaboy95
I e-mailed Jimmy Jams about their micro switch bracket. They told me It would work with my Holley t-body "with some slight modifications".
Hey Matt! Time to get the tools back out...LOL
Frank
