NX TPS switch bit the dust
When putting my system together, I used ALL NX stuff. EFI kit, Gen X-2, "Maximizer" controller, and NX TPS activation switch.
I've spent a few weeks getting the system wired, and I haven't even used it yet. Everything is wired as per NX's wiring diagram. Tonight I was testing my purge, and while doing so, my NX TPS switch activated. For those unfamiliar with the NX TPS switch, it taps into the factory TPS wire at the computer. When the TPS gets to 4.0 volts, it activates the NX TPS switch. On my system, it then sends a signal to the "Maximizer". This thing activated tonigth with the car NOT RUNNING ,and the throttle closed! This thing worked "as advertised" a few days ago when I was adjusting it.
I figured maybe it was getting a false signal from the TPS/computer, so I unhooked the activation wire. The LED stayed lit, and the switch stayed on! It now comes on as soon as the system is armed, and it starts running the program in the "Maximizer".
I'm certain this isn't a wiring problem. It activates with just the hot and ground hooked up...Even with the relay unhooked!
I planned on spraying for the first time tomorrow, but now it looks like I'll have to make motor passes only.
Anyone else have one of theses TPS switches? Anyone else has a problem with them?
Frank
Frank
Re: NX TPS switch bit the dust
Originally Posted by Mr_Bond
Did you check the volts in white wire on the TPS to see what it says at close throtle when the light is on? Did you adjust the screw?
I've turned the adjustment screw to it's extremes. This thig was working when I first put it on. This happened suddenly...I hadn't touched any adjustments.
NX told me to send it back, and they'd replace it. The only thing I've got to pay is shipping.
Frank
Sounds to me like the relay is bad and is stuck closed. Check all of your relays to be sure. Man that sucks. I was hoping to hear of a 10 sec pass this past weekend.
Matt
Matt
Matt
Matt
We'll try for that 10 second pass in a few weeks
Hmmm...10SCNDZ???? Frank
You need to ditch that thing and get a manual swithc like mine. After that failure I'd be really scared to run that switch. If it were to fail...kaboom. You should go to Nucar and grab a mechanical swithc and try it out this weekend
Good Luck
Matt
Good Luck
Matt
Good Luck
Matt
Good Luck
Matt
Frank
Originally Posted by 12SCNDZ
I've got the micro switch that came with the kit, but I can't figure out a way to mount it on my Holley T-Body
Frank
Frank
Same thing just happened to me. Switch was fine for the first few runs, then I noticed like a surging effect. Looked at the TPS switch and it was glowing red when the key was turned ON/Accy - Nitrous system not armed.
Unplugged the wire to the TPS Sensor, and it was still lit! I played around with the ****, and got it to activate the system, but that red light is pissing me off. Before I send it back, I am going to isolate it from the system and see if it works. Mabey it is somehow feeding back + power somewhere in the system???
Unplugged the wire to the TPS Sensor, and it was still lit! I played around with the ****, and got it to activate the system, but that red light is pissing me off. Before I send it back, I am going to isolate it from the system and see if it works. Mabey it is somehow feeding back + power somewhere in the system???I e-mailed Jimmy Jams about their micro switch bracket. They told me It would work with my Holley t-body "with some slight modifications".
Hey Matt! Time to get the tools back out...LOL
Frank
