no2 shot size
Old Dec 20, 2007 | 06:43 AM
trans 96's Avatar
Question no2 shot size
what would be a safe size dry shot for my car with no head work and 115000 on the clock? or would it be a bad idea?
Old Dec 20, 2007 | 06:18 PM
slowride94z's Avatar
take it from me dont go over 100 hp. make sure you have enough fuel pressure or better yet a new pump. tune, 685 mallory or equv for spark retard . start small then move up . happy spraying
Old Dec 21, 2007 | 08:48 PM
HardcoreRM125's Avatar
Honestly, you might want to look at a wet kit. Dry Kits for LT1's are not as effective as many other dry kits out there.
You absolutly CAN NOT run a dry kit without new injectors. And if your dishing out the cash for new injectors, you mind was well go with a Wet plate or nozzle kit. Under a 200 shot, you wont have distribution problems.
On a stock motor, with that kind of mileage, I would spray a 100 shot. Many spray more, but 100 seems to be a safe limit. Do a compression/leak down test first too to see any problems that might arise.
Old Dec 22, 2007 | 12:24 PM
2000GTP's Avatar
I would probably do some engine health checks to before spraying. Look into doing a compression test and cylinder leakdown test. If everything checks out, a 100-125 shot should be safe. Don't sacrifice on the safety items and you should be able to spray safely and still get more mileage out of your engine.
RX Speed Works
Aug 20, 2015 03:40 PM
Cam's maro
Aug 11, 2015 07:45 AM
NewsBot
Aug 3, 2015 02:40 PM
Boss002
Jul 24, 2015 10:47 AM
Slayer
Jul 4, 2015 03:06 PM
