Nitrous Wire routing, where?
where are you guys pulling your wires at thru the firewall? I cant find anywhere to come thru. I need a place for my wires so I can hook them up to the switches..
thanks
thanks
Re: Nitrous Wire routing, where?
2 screws get the computer out of the engine bay, then theres a VERY easy to access rubber piece you can poke a small hole through. Make sure you patch it up as best you can though.
I drilled a hole right under my brake booster which will put the wires right under your dash and easily hidden under the hood make sure if you do that to use a grommet tho I learned the hard way
Lata
Lata
