Nitrous Wire routing, where?
Old May 9, 2005 | 12:22 PM
Wishmaster's Avatar
where are you guys pulling your wires at thru the firewall? I cant find anywhere to come thru. I need a place for my wires so I can hook them up to the switches..
thanks
Old May 9, 2005 | 12:30 PM
RacerTim's Avatar
Re: Nitrous Wire routing, where?
2 screws get the computer out of the engine bay, then theres a VERY easy to access rubber piece you can poke a small hole through. Make sure you patch it up as best you can though.
Old May 9, 2005 | 01:33 PM
Wishmaster's Avatar
this is for a 3rd gen camaro not a 4th gen. any other locations?
Old May 9, 2005 | 01:49 PM
BlownF1's Avatar
With a drill bit and a rubber grommet, you can put it wherever you want it.
Old May 9, 2005 | 02:09 PM
LWillmann's Avatar
It's possible to run into the car from the vent at the base of the windshield. I ran my amp power through there when I had an '82 Camaro.
Old May 10, 2005 | 01:32 PM
KirbyZ28's Avatar
I drilled a hole right under my brake booster which will put the wires right under your dash and easily hidden under the hood make sure if you do that to use a grommet tho I learned the hard way
Lata
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
