Nitrous timing retarding
Old May 19, 2008 | 11:52 AM
nittanylionlt1's Avatar
I'm running an LE-2 setup right now. I'm running a stock ignition system. I just got a 125HP wet nitrous kit.
Should I go with an MSD type of ignition box with a timing retard or just retard the timing in the chip instead? I have no experience with the ignition boxes but I can edit my own bin files. I'm swaying towards the igintion box so I would have to run two different chips (one for NOS and one for normal). Although I'm not sure if the ignition box timing retard is just above a certain RPM or how that's configured.
Does anyone have a similiar situation?
Old May 19, 2008 | 12:09 PM
69gto96z's Avatar
I used a Mallory 685 ignition box. It seems to be the most popular and has never given me a single problem. Might try surfing the nitrous section though.
Old May 20, 2008 | 08:10 AM
2000GTP's Avatar
I would say the Mallory box has the upperhand versus having two programmed chips. With the Mallory, you not only get the timing reduction feature, but you also get a window switch, and the benefit of a hotter spark which might not be a bad thing for a heads/cam motor.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
mikey4play
Mar 15, 2015 11:45 AM
bandit383lt4
Dec 21, 2014 09:12 PM
