Nitrous and timing
Old Sep 11, 2009 | 02:46 PM
CamaroSS30thAnn's Avatar
Nitrous and timing
I i have an Lt1 with a rebuilt 350 forged rods pistons, aftermarket crank. Also the GM847 cam with ported heads and larger valves. 30#lb injectors 255lph in tank pump and the zex 125 dry shot with colder plugs etc. There are few other misc options like LT headers the normal. Car right now has a tune just to pass emissions.
My question is with a basic tune just for motor if i wanted to plug in my nitrous and run it what kind of timing should i have taken? I have the mallory box and can do it with the push of the button.
I dont have the time to get a tune right now and im just looking for maybe 2 base runs with the nitrous.
When i had the stock motor with just LTs i pulled 4 degrees of timing and it worked well.
What kind of timing should i pull now and be farely safe for a few runs?
Old Sep 12, 2009 | 03:06 PM
bump
Old Sep 17, 2009 | 08:42 PM
jonesy's Avatar
I would still pull 4 degrees
Old Sep 18, 2009 | 06:46 PM
93v8clone's Avatar
where in ny are ya ?
Old Sep 23, 2009 | 07:31 PM
remaxracer45's Avatar
how much n/a power would you guess that is?
Old Sep 30, 2009 | 11:02 AM
buffalo and close to 400 wheel close bc of the bigger rear and tranny
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
