nitrous problems
Old Aug 18, 2002 | 01:43 PM
justahoe's Avatar
Unhappy nitrous problems
I just hooked help my nx kit with a 75 jet on my z. Grounded everthing proplery(I think) made all of the connections. The selnoids will work while the car is not running, with the systems on, and work with the car running a no juice flowing if you kit the micro swith. But the system does not seem to work when you are driving and kick it in. I get a little surge sometimes but that is all. Anyone know what may be wrong?
1995 Z28, 4:10s,hpp,cai,cat-back,pulley,nxwet kit.
Old Aug 18, 2002 | 02:43 PM
speedmiser's Avatar
Post
Have you checked to make sure that your linkage is ingaging your micro switch a full throttle? Maybe you need to re-adjust your microswitch.
Old Aug 18, 2002 | 03:03 PM
RacinLT1's Avatar
Post
Make sure the microswitch activates at full throttle like said above. Also make sure you dont have the Jets mixed up...ie: fuel jet on nitrous,nitrous on fuel.
remove the nozzle from the intake and hold it with a rag and see if it sprays out. Also if you dont have enough bottle pressure,you wont feel much (yes bottle pressure is that important).
Dirk
1997 TA A4
11.251@119.3 1.52 60',7.132@95.39 1/8
The RacinLT1
RacinLT1 pic's
Old Aug 18, 2002 | 10:52 PM
Z28ROC's Avatar
Post
Do you have a FPSS? it sounds like it's kicking the system off. Try backing it down a bit and see what happens.
Mario,
White 94 Z28
Yeah I got a few mods
Video
Black 87 IROC-Z
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
