nitrous and manifolds
Old Dec 19, 2007 | 10:16 AM
jbnavy's Avatar
Ive got my first lt1 car, and im wondering how well hey handle nitrous on the stock motor. im looking at running a 150 shot. also, whats the best way to plug to holes in the exhaust manifold from the egr stuff being removed?
Old Dec 19, 2007 | 10:20 AM
We have an N2O Tech forum... I'll move your post there. Many people spray both wet and dry nitrous 125-150HP, on the stock LT1 manifold and rotating assembly with no problems. How you do it will affect your end results. There are FAQ's on the N2O Tech forum that cover basic nitrous info.
No one can tell you how to block the exhaust manifold for AIR and EGR unless you tell us what year your car is.... there are three different configurations of the connections used on the LT1 from 93-97.
Why not add a "signature" showing basic info about your car.... year, model, engine, tranny and any major mods?
Old Dec 19, 2007 | 10:27 AM
jbnavy's Avatar
it is a 1994 trans am gt with a 4l60e stock other than cold air intake and all smog equipment removed
Old Dec 19, 2007 | 11:22 AM
You have three connections on your exhaust manifolds. There's an AIR injection port on top of each manifold, that can be plugged with an M22 oil drain plug, with copper gasket. There is a single EGR connection (exhaust riser tube) on the rear of the passenger side manifold. That gets blocked with a bolt-on plate. sjmmanufacturing.com sells the blocking plates. You also want to consider plates for the EGR valve hole, if that has been physically removed, and (optional) add a cover plate to the intake manifold connection for the exhaust riser tube.
To add a "signature", so you don't have to type the info over again for every post, click on "User CP" on the red bar at the top of any page, then "edit signature".
Old Dec 19, 2007 | 11:41 AM
jbnavy's Avatar
so those will not melt from the heay?
Old Dec 20, 2007 | 07:08 AM
The steel oil drain plugs and aluminum EGR blanking plates will not melt, if that's what you were asking about.
GREEN3112
Feb 10, 2019 09:19 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
whitehooptie
Aug 17, 2015 08:35 AM
