Nitrous Line Fitting Cracked
Old Mar 31, 2003 | 09:37 AM
Camaro SS's Avatar
This may be a stupid question, but here goes. My main nitrous line has a leak at the fitting. Upon closer inspection, I can see a crack in the brass insert inside of the fitting. Can new ends be put on or should I buy a new line?
Old Mar 31, 2003 | 10:36 PM
LPEdave's Avatar
Yes, you should be able to put a new fitting on the end. If you don't know how, it may be easier to take it in to a speed shop if you've got one around...
Dave
Old Apr 1, 2003 | 12:22 AM
CustomN2O's Avatar
That is a tricky answer, becuase it could be answered both ways. Yes and NO. Its not a normal braided line. It is teflon lined. They do make fittings for it, but it depends on the brand of the line. You have to make sure the fitting matches the line. You have to make sure the little ferral fits the teflon lining correctly. There are a couple different sizes. The fitting is a special fitting for that type of line. THey are a little more expensive, and a real pain in the *** to install. Might be easier to just get a new one. BUt that is expensive.
Old Apr 1, 2003 | 01:38 PM
MonoxideChild's Avatar
I have a 16 foot nitrous line for sale for 75 shipped. if your interested.
email me, dmgov@netzero.com
Old Apr 1, 2003 | 01:54 PM
speedmiser's Avatar
Go to a local Parker or Aeroquip hose dealer. They can put a new zinc plated fitting on for less than $10.00. I think I paid about $5 last time I had it done. You can probably get a stainless steel fitting installed for $10.00
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
squarehead
Nov 21, 2014 08:02 PM
