Nitrous Install help!
Old Dec 8, 2004 | 06:59 AM
xfreshjiv12x's Avatar
Question Nitrous Install help!
I just purchased a nx kit on the boards here but I have a few questions about it. I have the solenoids and the two wires comming out are the same color, how do you tell which is which? Also the FPSS is conected to the fuel solenoid in part, I dont have the lines or fittings that connect it to the schrader valve, how would I go about getting a hose to fit? One more thing what type of relay should I use 40 amp? Any help will be GREATLY appreciated!
Old Dec 8, 2004 | 08:51 AM
slp223's Avatar
Re: Nitrous Install help!
the wires off the noids can be used for power or ground it does not matter which is which. 40 amp automotive relay. I am not quite sure about you question about the fpss.
Old Dec 8, 2004 | 11:46 AM
Ok great thanks for those answers! Ok with the fuel solenoid attached to the "in" part of it is the FPSS. Now I only have one of the lines, its the one that runs from the "out" on the fuel solenoid the nozzle. I am missing the line that runs from the schrader valve to the FPSS. should I just call NX and get it shipped or is it something I can get at a local store?
Old Dec 8, 2004 | 12:05 PM
slp223's Avatar
I have had those line made at a local shop the makes hydrolic line for construction. they cost about the same if you order them from nx or nos. the one i had made had steel ends not aluminum with color coded. I would just order them if you can wait a few days.
Old Dec 8, 2004 | 02:21 PM
Ok ill do that thanks SLP!
Old Dec 8, 2004 | 03:06 PM
crash4cyl's Avatar
Usually a local Speed shop will have the line. It's either -3 or -4 AN line. I think it's -4, that's what the TNT Kit had.
Old Dec 8, 2004 | 03:25 PM
Nitro Dave's Avatar
Correct the system comes with a 18 inch -4 line to go from the shrader valve to the fuel solenoid.
Dave
Nov 18, 2023 07:21 PM
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
