Nitrous and Hypertech Chip
Old Jun 29, 2002 | 01:53 PM
BigBadBlack93Z's Avatar
Post Nitrous and Hypertech Chip
On my 93z I have to run the hypertech chip because it removed the speed limiter. W/o the chip the car wont go over 105. Its the stage 2 chip, how much more timing is this giving me?
What risks do I run having this on and spraying a 75 wet shot?
Is there a better alternative to the hypertech, I'd like to find a stock 93 chip for the zrated tire cars so I can avoid this all together.
1993 Z28 Black A4
Speed Density RULES!
Visual Mods: C5 wheels 17xBig w/ 245/40-17 on the front, 18xHuge w/ 275/40-18 on the rear, No badges, 1" drop
Performance Mods: 1LE Bellows, K&N FIPK CAI, Granatelli STB, MAC Control Arms/Panhard bar, ES Torque Arm Bushing/Trans Mount, TB Bypass, SuperTrapps, Timing Tricker, Jet Air Foil, Hypertech Stage 2 Chip, ASP Crank/Alt Pulleys, Adj Fuel Regulator, 24# Injectors, 3.73 gears, Yank 2800
Future Mods: GTP Stage 2 stock heads, cc305 cam
Old Jun 30, 2002 | 10:27 AM
1FastRedZ's Avatar
Post
I'm not sure with the speed density (how much advance it gives it) but I pulled my Power Programing out. It does advance the timing and thats no good with spray. Sounds like you might need to get a custom chip, Just get that hypertech out before you spray it.
95 Z28 6 speed
Sprayed with other go-fast parts.
Old Jun 30, 2002 | 10:35 AM
donot_4get's Avatar
Post
You can get a custom chip from:
www.pcmforless.com
or you can directly e-mail Alvin (he is the one who do the chips for 93s for www.pcmforless.com) at
Rooster433@aol.com
hope it helps
leo
1993 Z-28
13.7s@99.97mph
SS hood
Rockford: amps, and sub
Cadence: EQ, and CAP 1.0
BM Quart: components
Pioneer: Head Unit
100% self-install
http://www.tereschubert.com/camaro
Old Jul 1, 2002 | 12:46 PM
speedmiser's Avatar
Post
I ran the same chip for about 2 years in my car (for the same reason). I used a 100shot compucar plate without a problem and without pulling out timing. You should have no problem at all with a 75hp shot.
I've always ran 93 oct. gas of course.
If I'm playin, I'm sprayin
93 Z28 A3 - w/ Jet Hot coated Hooker LT's and true 3" duals
(hiflow cats, cutouts, and Car Chemistry insert mufflers)
Old Jul 4, 2002 | 02:35 AM
speedmiser's Avatar
Post
If you're in doubt, call Hypertech and ask them what the max advance is over stock from 3000 to 6000rpm. I dont think you'll find the advance on the hypertech chip quite as aggressive as some of the other manufacturers like Fastchip or maybe Jet. I'm currently running a fastchip which has quite a bit of advance, but I'm not to familar with Jet. Regardless, you aint running either of those chips.
As I mentioned, I ran the same Hypertech chip in my 93 for approx 2 years with a larger shot, and experienced no problems. But if you still dont feel safe, send the chip back to Hypertech and have them pull some timing out, or buy a retard box. If you pull the chip out and hit that speeed limiter on juice, then you stand a great chance of scattering the motor.
If you were to damage your motor with the hypertech chip and a 75 shot, then I suspect you'd have other problems, instead of detonation. Like leaning out. I really dont beleive that the hypertech has enough advance to worry about. But hell, get it from the horses mouth and just get Hypertech on the phone before you make a decision.
[This message has been edited by speedmiser (edited July 04, 2002).]
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
92_RS_305
Sep 8, 2015 07:47 PM
colts0455
Sep 4, 2015 01:41 PM
