nitrous
Old Jun 11, 2005 | 05:57 PM
kobrakiller94's Avatar
nitrous
Will i be able to use a dry kit on my 94 lt1? And how big of a shot can the stock injectors handle?
Old Jun 11, 2005 | 10:39 PM
Re: nitrous
The most popular dry setup for the LT1 is the NOS 5176. Good for 125-150HP. But you would need to swap out the injectors, not for larger ones, but for a different type. The dry kit increases fuel flow through the injectors (when you spray) by boosting the fuel pressure to 85-90psi. The stock RP ball and seat injectors will not operate reliably at these pressures, and need to be replaced with a pintle type injector (Bosch, Denso, Ford SVO/FMS, etc.).
I ran the 5176 for 5 years with no problems, using Ford/Denso 24# injectors and NGK TR6 plugs.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
