New To N20
Old Nov 13, 2004 | 05:23 PM
xfreshjiv12x's Avatar
New To N20
Ok fellas Iam new nitrous I just bought a NX wet kit for my 130,000 94Z its basically stock except for minor mods: cai, 3.73, A4, HPP+. Iam wondering what else I have to do? Should I still use the hypertech program or return to stock? Should I get bigger fuel system (only planning to run 100-150 shot)? And about spark plugs I have iridium NGK plugs, what gap should I use? any other useful info would help out alot thanks!!
Old Nov 14, 2004 | 07:46 AM
Re: New To N20
Cany anyone help me?
Old Nov 14, 2004 | 08:22 AM
sssalah's Avatar
Re: New To N20
You could go upto 125 hp safely, if you want to go 150 then get a bigger fuel pump. Remmeber NX rates by rwhp so the 150 is around 175 fwhp. I hear the stock fuel pump is maxed out at 450 hp.
I don't know about the iridium but I guess they are similar to platinum which have a small tip that could get realy hot and cause detonation. Most people are more comfortable running regular copper plugs like the ngk tr6 gapped at 0.35".
Old Nov 14, 2004 | 11:09 AM
Re: New To N20
What about timing? I hear people talking alot about timing. Also would the hypertech programmer need to be uninstalled or is it ok to keep it? Anyone else use iridium plugs with nitrous?
Old Nov 14, 2004 | 12:49 PM
sssalah's Avatar
Re: New To N20
With this power level you don't realy need to pull any timing. After the 100 level you can start taking 2 degree per 50 hp.
Just to be extra safe, disable the engine tune with the hpp. I've compared stock and hpp timing tables, and out of the hundreds of cells in that table there are only 6 cells that were slightly different.
Old Nov 15, 2004 | 08:46 AM
Re: New To N20
I did some research on the iridium and they say its better than plantnium and is fine to use with nitrous. I currently have the gap set at .050 should i set it at .035 like you said? Should I get colder plugs?
Old Nov 16, 2004 | 01:28 AM
bo3abd's Avatar
Re: New To N20
i got a 150,000 94 Z-28 with a-4. with 2800 stall and 3.73 gears. i used to run nx wet system with 150 shot and bone stock engine and stock fuel pump every weekend with no problem at all. don't use a plantnium plugs coz they melt with nitrous use. i'm using NGK tr6.
i also was using the hpp. leave the shif point stock coz i tried to play with them with no good with nitrous.power shifting was on. i adjust the gears ratio and tire size. i ran best of 12.4 @ 114. with 1.9 60ft.
Old Nov 16, 2004 | 03:46 PM
Re: New To N20
OK that helps alot guys!
Old Nov 16, 2004 | 07:42 PM
Heatmaker's Avatar
Advanced Member
Re: New To N20
DOes NX come with fuel pumps?
Cbr02
Aug 24, 2015 07:12 AM
ELLTEE1
N2O Tech
14
Jan 20, 2003 03:41 PM
therealmagyver
Jan 12, 2003 09:33 AM
snake_killer
N2O Tech
Dec 10, 2002 07:15 PM
96z
Sep 19, 2002 10:45 PM
