New to the juice Need a WOT switch
just put a 100 shot in ghetto rigged it with a push button on/off switch. where can i order a WOT switch? i have a bbk so i cant use jimmyjams. i saw one over at nitrousexpress.com $45 with a relay. do i need the one with the relay? does anyone else have one that will work for me? wheres the cheapest place for and rpm activated switch
thanks
ohoh when i hit 5000rpm sometimes if feels like something cuts off then back on. like im not getting enough spark or something. like a little hesitation/miss. you can hardly feel it
thanks
Summit racing has the window switch for $76, but check with T-bryne since they will pricematch -10%! You could also post on the wanted board for one, or check EBay, I see them on there for around $40 to $50, sometimes even with the pills. No idea on what you can do for a WOT switch bracket. I think TNT sells just the switch for $15 or so, but you'll have to rig a bracket up. I should have a used WOT switch in a few days with some other stuff that I can sell cheap.
Good luck!
Good luck!
jackpawt883
Sep 10, 2015 08:53 PM
