new car with nitr4ous question
I just bought a 94 camaro LT1 and it has a N20 kit installed. it looks like a dry kit since there is only one line going into the nozzle. it is mounted right before the tb plates after the Mass Air flow sensor...Is this right?? I always thought you put it before the MAF sensor and let it flow through it
thanks
Dustin
thanks
Dustin
Re: new car with nitr4ous question
Im pretty sure you want to mount it between the TB and the MAF as it is....i have a wet kit and im sure its the same for a dry kit.
http://www.harrisspeedworks.com/gall...s.php?album=27
Thats what mine looks like....tell me if it looks similiar to yours.
No, The dry system mounts between the air box and the MAF. The nitrous needs to flow threw the MAF in order to make the fuel adjustment.
A wet system adds fuel with the nitrous so there is no need to flow it threw the MAF. Hope this helps.
NOOOO! You will greatly increase your chances of blowing your car up by doing this. A dry kit runs a vacuum line from the silonoid to the fuel pressure regulator. Extra vacuum is applied to the regulator to increase fuel pressure.
I reccomend NEVER spraying pre meter
http://www.holley.com/data/Products/...135-SNOS-1.pdf
ChrisFrez
Dec 21, 2014 09:47 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Nov 23, 2014 10:33 AM
