need fitting to attach the following to schrader valve.
Old Apr 12, 2009 | 06:27 PM
SMO Q's Avatar
1995 z28, Im running a NX efi wet kit, and I have a fuel pressure saftey switch hooked up to a fitting off of the schrader valve, I also need to hook up a stewart warner electric fuel pressure sending unit to the schrader valve but I cant find a fitting to do this because of the limmited space. This might be in the wrong forum, if so, Im sorry but can any one help with how to hook these both up? Ive done a search but it didn't help.
Old Apr 12, 2009 | 11:50 PM
Start with an NOS #17585 -4AN 90-deg swivel fitting. That gets the connection faced sideways, instead of up at the cowl, and eliminated problems with over-tightening the fitting on the Schrader to get it facing in the correct direction. Then figure out where you can put a 1/8NPT all female "tee" fitting. Get a short length of braided S/S hose with a -4AN female on one end, to connect to the swivel fitting, and a 1/8" NPT male on the other end to screw into the brass "tee". Now you have two 1/8" NPT connections available, one for your pressure switch, and one for your gauge pressure sensor. Typically, both of those devices have 1/8" NPT male threads. The "tee" has to have all female connections.
The brass tee is a low cost hardware store item. If you want a nitrous system distribution block, NOS makes several of them with 1/8" NPT.
http://www.holley.com/types/Distribution%20Blocks.asp
I though NX had a "manifold" for multiple connections. Where did you hook up your fuel line to the solenoid?
Finally, there an N2O Tech forum, with a couple of very good Supporting Vendors, who will have even better suggestions than I gave you. I'll move your thread to the correct forum.
Old Apr 13, 2009 | 06:55 PM
SMO Q's Avatar
Thank you!
PROJECT X
Apr 17, 2015 12:13 AM
mattstrike
Mar 11, 2015 07:33 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Jul 4, 2005 05:00 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
