n2o gearing
Re: n2o gearing
i dunno iv been doing alot of talking with my mechanic and he thinks i should go 4.10. we just finished installing a tci 700-r with manual valve bodies so i haveto shift it manually but it has a toggle switch for the overdrive.
Re: n2o gearing
Gear selection needs to be based on engine redline, trap speed, tire diameter, convertor slip, tire growth, etc. There is no "standard".... it depends on the specifics of your car. I run 4.11's with a TH400, and a high stall convertor. But I've also got a pushbutton activated Gear Vendor OD for running traps over 131MPH. What gears you need depends on your specific setup.
Re: n2o gearing
Dont go 4.10 go 3.73 because if you go 4.10 you cant step up to a 28 inch tire to compensate with cutting you rear fenders
my A4 and 3.73s with N20 runs perfect for the 1/4 mile.
Re: n2o gearing
28x11.5-15 QTP's fit without cutting the fenders/bumper cover. Did require moving the rear axle back about 1/4" to avoid rubbing on the leading edge of the fender opening. 28x10.5-15W ET Drag is a whole different story.
Re: n2o gearing
The good thing about nitrous is that it will make the power without needing crazy rpm.... Nitrous makes most of its torque at moderate rpm, so 3.73's will be prime..... I couldn't decide between 3.73's & 4.10's, so I went 3.90's.. lol... but on 150 shot, my car goes 11.20 @ 120, on 350 shot, 10.41 @ 132..
Re: n2o gearing
Originally Posted by sssalah
No such thing for a 7.5" 10 bolt rear.
All i know is 6speed/first gear/nitrous/4.11s its INSANE. I love it. But you have an auto so it might be different. Im only giving out the "fun" perspective as i havent tried it at the track yet.
Re: n2o gearing
Actually i havent ever used it.lol I sold my truck and now the alarm is just sitting here. I have a viper alarm on my hawk but wouldnt mind having the auto start on it. So dont know if its worth swappin alarms out.
