n20 timing retard question.
Old 10-07-2008, 07:41 PM
94GreenMachine's Avatar
I'm wondering when to retard the timing, when the n2o engages or at a specific rpm. I'm running a mild bolt on motor on a stock tune for the time being (until winter when it goes under the knife) and I know I don't theoretically need to retard the timing for safety reasons but want to do it anyway to see if I can't gain a little top end as well as be safer, etc. for example, I'm running an msd6 digital and a nitrous outlet dual window switch with the lt1 plate system at a 100 shot. Should I set the timing retard to activate on the first window stage when the nitrous starts at say 3000-3500 rpms or on the second switch at a higher rpm like 4500 rpms, etc.
thanks.
94GreenMachine is offline
Old 10-08-2008, 09:51 AM
Ray@NitroDaves's Avatar
copied from LTXtech.com
Here is a diagram I made for another LT1 guy...the wire marked for the Crane ignition retard will connect to the retard wire on your MSD box also.
Stroked96bowtie was correct that you will want the timing pulled as soon as the solenoids are active.
Please let me know if you have any other questions.
Ray@NitroDaves is offline
Old 10-11-2008, 01:32 AM
ray thanks for the diagram it will come in handy in a couple days when the kit arrives.
10-31-2016 11:09 AM
mikey4play
03-15-2015 11:45 AM
alex5366
02-17-2015 10:43 PM
alex5366
02-17-2015 09:07 AM
Deadbolt24
01-19-2015 01:29 PM
Quick Reply: n20 timing retard question.
