MSD Digital 6 Box Mounting
Old Sep 15, 2004 | 09:35 PM
SnakeSkinner28's Avatar
Hey, i was wondering where yall that have this box have mounted it in their cars. Im having clearance problems if mounted on the strut tower, the firewalls a pain in the ***, so any suggestions on where to mount would be apprieciated.
Old Sep 16, 2004 | 01:18 AM
fastcamz28's Avatar
Re: MSD Digital 6 Box Mounting
I just mounted mine last week right behind the fuse box on the driver's side in the engine compartment. I faced the dials, etc toward the brake lines. The fuel lines run across the upper corner of the unit. It was the only place I found that had enough surface space to acomodate the Dig 6. Hope this helps. I can take pics and email them if you pm me.
Old Sep 17, 2004 | 11:05 PM
DisturbedZ28's Avatar
i mounted mine in the same spot..i also put some rubber extra rubber tubing around my fuel lines to protect them from getting scratched/split on the end of the msd box
Old Sep 17, 2004 | 11:46 PM
kirschman's Avatar
http://gallery8926.fotopic.net/show_...n.php?id=23663
there's a pic of mine on the last page. Moved the fuse box under the msd, made a plate to mount it on and just screwed it to the original fuse box bracket. Not sure if my 6AL is the same size as the digital or not though.
Old Sep 18, 2004 | 04:00 PM
gb95zconv's Avatar
[QUOTE=kirschmanMoved the fuse box under the msd, made a plate to mount it on and just screwed it to the original fuse box bracket. .[/QUOTE]
I did the same thing for my Mallory unit. One other option is to relocate the battery to the trunk and mount your box where the battery was.
Old Sep 21, 2004 | 06:14 PM
rpm4lalo's Avatar
I removed my passenger side airbag and mounted my Mallory 685 Ign. Box inside there.
Old Sep 21, 2004 | 11:11 PM
DrewHMS97SS's Avatar
i guess i have it a little easier than most fbod guys.
Picture 1
mr28
Apr 20, 2016 05:44 PM
mr28
Nov 23, 2014 11:11 AM
Don 97 SS
Jul 11, 2005 08:50 AM
