MSD Dig Window Switch and Delteq question??
Old May 29, 2005 | 10:38 PM
Camaro90RS's Avatar
I am trying to finish the wiring on my NX wet kit, and I have a few questions on what to set the cylinder mode to. Since I have the Delteq system, its called a waste spark ignition system, and therefore I would need to set the Window switch to 2 cylinder mode, but the problem is that I still have the stock computer system and the opti as my "crank trigger" for the Delteq. So Can I just set the window switch to 8 cylinder mode and pull the tach signal from the computer wiring harness, or do I set it as 2 cylinder mode and pull the tach signal from somewhere else(like the Delteq system).
If I could get some help on this, it would be greatly appeciated.
Old May 30, 2005 | 05:38 PM
Camaro90RS's Avatar
Re: MSD Dig Window Switch and Delteq question??
Does anyone have any ideas
Old May 30, 2005 | 10:26 PM
LWillmann's Avatar
I would assume you'd want to run it off the tach signal from the stock wiring harness.
capebuf
Jan 13, 2015 07:22 PM
Ari G
Dec 11, 2014 03:21 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
