Max hp jetting on a plate?
Old Oct 6, 2007 | 12:54 PM
funina91ss's Avatar
I have a N.O.S. T.B.I. Plate on my RS I was wondering what the max hp it will flow? and what the jets would be to go about it. (from a 150 up)
Old Oct 7, 2007 | 07:20 PM
AutoRoc's Avatar
You'd want to do some number punching to figure out nitrous to fuel ratio, especially if you use the wierd TBI fuel pressure. isn't that 10-15psi roughly? It would be a very different jet spread than a 6psi or 40psi tuneup.
As for the plate's capabilities, I've never seen the design. is it a perimiter or spray bar type? I bet it can flow more than you need but working your way up from 100-150-175-200 can be done safely. If it can't flow more, you'll see no gain in performance basically.
Old Oct 8, 2007 | 10:57 AM
funina91ss's Avatar
right now for the 150 jet I am using a 68 N20(I think) and I know I am using a 41 fuel jet, it called for a 46 but it was way to rich. All tuning will be done on a dyno with a wideband (that is how we got where we are right now.
The plate has two bars in the middle of the plate. I guess I am going to have to us some math to figure out what jets to use.
First pull was a 298hp and 404 tq leaned it out and it went to 311/424
But we will be tuning the motor this week to get the fuel lined out on it. (its way rich NA/ and on the spray from 3-4200rpms.
GREEN3112
Feb 10, 2019 09:19 PM
Ericksd
Jan 20, 2016 06:07 PM
95blkss
Sep 22, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Devinfoote87
Jul 30, 2015 09:54 AM
