Mallory 685, will the staging control override the window switch?
Old Jan 3, 2009 | 03:56 AM
speedracer2j's Avatar
Ive searched with no definite answers, but
Has anyone tested to see if while using the mallory 2 step function, does this disable the window switch?
Old Jan 4, 2009 | 09:39 AM
jakesz28's Avatar
I did not actually test that and wondered about it myself but I just used a relay to make sure that the window switch did not cause the nitrous to spray until I released the transbrake(which activated the two step).
Old Jan 6, 2009 | 10:25 AM
Ray@NitroDaves's Avatar
you will need to use a relay to cut power to the kit when you are on the 2 step.
here is a diagram showing the wiring for a trans brake...the 2 step would wire the same way
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
