lt4 km and nitrous
Old Jul 6, 2002 | 07:22 PM
muraoka's Avatar
Post lt4 km and nitrous
can you run the lt4 km and spray?
my 97z m6
lt4 knock mod, hpp3 (for gears & fans),k&n cai,160 stat,holley annihilator,lasershot coil,4.10,g2 girdle,hurst shifter,stb,sfc,boxed lca,tubular panhard,energy bushing thru out,pro flo muffler,zr1s 17x9.5(50mm&38mm)275/40/17gs-c,285/40/17gs-c,big block hood,98 ss spoiler,window tinting,pioneer deh-p7300,cdx-fm657,obocon w/2 rockford hx2 10s,phoenix xs2300,and nittos.
best e.t. 60'2.107 1/4 13.328 mph 105.16 track elevation 2240
Old Jul 6, 2002 | 10:36 PM
LPEdave's Avatar
Post
Sure. It's a bit less sensitive to knock, but as long as your nitrous sytem is tuned safely, no problem.
Dave
1997 LPE 383/n2o Camaro Z28 Convertible
12.39@112.2, 1.76 60' (na) 11.27@124.6, 1.76 60' (n2o)
LT1 Diagnostics, New to Nitrous? Northern California Racing Club
Old Jul 7, 2002 | 11:31 AM
n2oTransAmLT1's Avatar
Post
I agree. I have been running nitrous and the lt4 km for almost 5 months now. Not a problem. However, I did have my computer reprogrammed to run nitrous with that module.
`96 TransAm: RamAir w/ K&N filter, 125hp Zex dry kit, 3.73 gears, McLeod StreetTwin clutch, Borla cat-back, 1le alum. driveshaft, B&M shifter, Walbro in-line fuel booster pump, Granatelli MAF, 52mm TB w/Airfoil and coolent bypass, LT4 KM + programmed computer, Accel 8.8 race wires, Zex Hyperformance plugs, MSD Univ. Adj. timing, Window switch, Sport-comp Nitrous, Boost, Fuel pressure gauges in center 3 vents and Air/Fuel gauge on A-pillar pod, Mobil 1 only, !CAGS, Yokohama tires, tinted windows.
Low 13's on motor.
Low 12's on bottle.
"Lots of throttle and a backup bottle"
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
95blkss
Sep 22, 2015 03:18 PM
