lt1 +100shot car falls on its face,
Old Mar 31, 2007 | 10:31 AM
kline454's Avatar
my 1995 camaro 383+100 shot wet falls on its face when you hit the n20 then comes out of it and runs great? plugs look good, im on a mail order tune for the 100shot any ideas?
Old Mar 31, 2007 | 10:50 AM
Moshbmx1's Avatar
Do you have a fuel pressure gauge hooked up? Do you have an aftermarket ignition? Are you retarding timing when on spray?
Old Mar 31, 2007 | 11:00 AM
kline454's Avatar
msd6a tr6 plugs the timing is retarded in the tune. no fuel pressure gauge, i do have saftey switch, not sure what pressure the switch is set at i just set it up like the kit said, hold the engine at around 3500rpm spary the fuel into a can turn the srew in till it cut of the fuel then back out 3/4 turn.
Old Mar 31, 2007 | 01:07 PM
396D1SS's Avatar
whats the bottle pressure when running? You should have your tune set up for all motor. You do not need to pull timing with a 100 shot.
Old Mar 31, 2007 | 01:27 PM
U Can't Z Me's Avatar
This might be kind of obvious, but do you have the right jets for the right things?
I once put my fuel jets on the nitrous side and the nitrous jets on the fuel side...basically it gives you about a 25 shot with enough fuel for a 250 shot
It did the same thing.
Old Mar 31, 2007 | 03:26 PM
kline454's Avatar
yes i rechecked the jets and bottle was @ 1000psi.
Old Mar 31, 2007 | 05:13 PM
2000GTP's Avatar
I would put a FP gauge on it and make sure the fuel pressure doesn't dip under WOT or the spray. If it does, your pump most likely isn't keeping up.
Old Mar 31, 2007 | 05:16 PM
Ray@NitroDaves's Avatar
pulling timing for the 100 shot will depend on how aggressive the timing is for NA use.
as stated before it would help to know what the Fuel pressure is doing upon activation, and what the A/F is during the pull.
Old Apr 3, 2007 | 06:28 PM
buzz12586's Avatar
If you don't purge the line sometimes the fuel can reach before the nitrous does and cause it to bog right when you hit it and then pick back up.
Old Apr 5, 2007 | 06:12 PM
kline454's Avatar
well thanks for the help, turns out that my fuel pressure is droping to about 25psi when i spray,
Old Apr 5, 2007 | 06:16 PM
2000GTP's Avatar
Looks like you found your problem, sounds like you need a pump. You may want to verify what your FPSS is set at as well. If your fuel pressure is dropping to 25psi and your FPSS isn't cutting off the nitrous system, then you may need to tweak it some.
Old Apr 8, 2007 | 02:05 PM
Soccerbum21's Avatar
he might only have the fpss to cut off the nitrous solenoid only.
Old Apr 8, 2007 | 09:00 PM
kline454's Avatar
yeah the FPSS was set to kill it at 20psi, thats going to change i didnt know thats how low it was set,
onefastgta
Mar 19, 2015 10:10 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
bernie1951
Dec 10, 2014 10:03 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
USAirman93
Nov 24, 2014 03:37 PM
