LS1 Timing Retard for Nitrous
Old Mar 25, 2007 | 04:58 AM
BlueCamaroZ28's Avatar
What is a good Nitrous activated timing retard box for LS1, Compatible with Multiple Coil Ignitions?
Old Mar 25, 2007 | 03:29 PM
Ray@NitroDaves's Avatar
this is the best one on the market....
http://www.nitrousoutlet.com/catalog...product_id=965
Old Mar 26, 2007 | 12:01 AM
How does it work? Any information on wiring and installation?
Does trigger timing retard with nitrous activation per preset values?
Old Mar 26, 2007 | 09:04 AM
it wires inline with the crank position sensor. When it activates the kit it sends a the retarded timing signal to the PCM. This way you still have your normal timing for NA use. It can pull up to 12* of timing.
here is a link to the instruction manual
http://www.fullthrottletech.com/atta...2&d=1103730053
Old Mar 26, 2007 | 02:12 PM
Great. Thanks.
Old Mar 31, 2007 | 11:56 PM
Is there a devise that combine the functions of this, timing retard and window switch, with Nitrous Progresive control?
Old Apr 1, 2007 | 01:41 AM
Originally Posted by BlueCamaroZ28
Is there a dvise that combine the functions of this, timing retad and window switch, with Nitrous Progresive control?
not at this time....
mikey4play
Mar 15, 2015 11:45 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
