Looking for a Nitrous Kit, But I'm a Newb to N20
Old Feb 15, 2008 | 01:43 AM
Counted Out's Avatar
I have a mostly stock engine, besides what's listed in my signature, so would it be best to go with a wet or dry kit?
I've heard of some kits being "upgradeable", how do these work?
Links to some kits for LT1's would be highly appreciated.
Old Feb 15, 2008 | 01:46 AM
porksoda's Avatar
Matt and Mike at Harris Speed Works are awesome to work with! Just give them a call or PM and they will answer all your questions.
Old Feb 15, 2008 | 07:16 AM
2000GTP's Avatar
Check out the link in my signature, they are a great company to deal with. As for the "upgradeable" aspect, there are alot of accessories that can be included in your setup. I bought the NX kit from Nitro Dave and it basically contained the wiring, the bottle, the plumbing, and the bottle. I added a Mallory 685 ignition box, a 860 spare tire well mounting plate, the GEN-X2 upgrade which included the fuel pressure safety switch and purge valve, and a Jimmy Jams ashtray switch panel. Now that all of that is done, I'm actually thinking about pulling it all out, sending my spare intake manifold to Nitro Dave, and having him set it up for a direct port. (I'll be PMing you soon Dave. ) You might also want to refer to the sticky that is on the forum page, it will give you some good ideas on the safety devices needed to safely and consistently spray.
Old Feb 15, 2008 | 09:26 AM
Ray@NitroDaves's Avatar
I prefer wet kits for the LT1 as I do not like increasing the fuel pressure for the fuel enrichment.
Some kits have certain flow limits, "upgrades" remove those limits.
As you have seen there are many options out there, if you could let me know what your plans are for your car, both now and in the future, I can help pick the kit that best suits your needs.
Old Feb 16, 2008 | 02:21 AM
PM sent.
Old Feb 16, 2008 | 09:45 AM
'94 Bad A Z28's Avatar
Go with a wet kit, and get your self a new fuel pump while you are at it, something like a Walbro 255.
Old Feb 16, 2008 | 10:51 PM
ltwonz's Avatar
Make sure you go wet kit, our 93's don't have maf's to increase fuel. Just have Ray set you up with a wet kit and you'll be more than happy.
Old Feb 16, 2008 | 11:33 PM
2000GTP's Avatar
Generally, the dry kits for the LT1 don't spray before the MAF anyway. They have a nozzle that goes after the MAF in the elbow and use some sort of vacuum signal to "trick" the fuel pressure regulator into spiking the pressure and providing the necessary extra fuel.
camaroguy50613
May 27, 2016 09:00 AM
bandit383lt4
Dec 21, 2014 09:12 PM
Brendans Z
Sep 11, 2002 05:29 PM
