Lifting heads
Old Feb 7, 2007 | 10:37 AM
z2894droptop's Avatar
Lifting heads
I have heard of it, but I am not sure what causes it. What can I do to prevent lifting the heads?
Old Feb 7, 2007 | 10:53 AM
tireburnin's Avatar
It is caused by high/excessive cylander pressure. It usually occurs when lots of nitrous is used with improper timing.
It can be prevented with good tuning, good head gaskets and head studs.
Old Feb 7, 2007 | 07:14 PM
andy katzelis's Avatar
Right on, excessive cylinder pressure from detonation. You'll know it happened when smoke pours out of the exhaust. Upon head removal you'll notice that the bolts are loose.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
