Which knob is the fuel test port on a LS1? Also...
Which **** is the fuel test port on a LS1? Also...
Which is the fuel test port on the LS1? Do you need that vavle stem core remover? And what part do you need to put in there? I got a used kit and will have to order the part.
Also, where did you mount your solenoids on your LS1s?
Thanks for the help
Thanks for the help
Just follow the fuel lines, at the end of the rail there is a black cap, you are correct you have to remove the stem, then hook your fitting onto that. As for the noids you can put them where ever, mine are just underneath the windshield. Most people put the fuel noid mounted right on the fuel rail. I have some pics of it on my website.
Good luck and enjoy the fun!! N20 rocks!!
squarehead
Nov 21, 2014 08:02 PM
