Which Kit???
Which Kit???
I was looking at these 4 kits, the 2 gems are the same but diff bottle size. Let me know what you guys think, I like them both alot but wanted opinions. Any help along would be great. thanks .
http://store.summitracing.com/egnsea...=KeywordSearch
Both the NXL and the MAF kit are excellent products.
I am running the MAF kit on my 94, and have been very pleased with the simple look of the install and the fact it can support up to a 500 shot in a 2 stage configuration.
THe NXL will give you the ability to tune each cylinder's A/F independently but puts a huge demand on the fuel system due to the volume of fuel needed to fill the fuel rails. Some cars will need to add the fuel accummulator to keep from seing a lean spike upon activation.
It is part # SPEED00010 and retails for $199
Not all cars will need this, but we tell every one looking at the "rail" based systems to watch it.
Either way you go will be an excellent choice.
PN-80010-10NXL is the kit for the LT1...PN 20220 is for the LS1 and will not work for the LT1.
The 80010-10NXL is a standard Direct port kit using NXL nozzles, where the 20220 is designed for the LS1 using integrated rail and solenoids.
With the 80010-10NXL if you use the distribution blocks, or the rail upgrade you have less need for the accumulator.
This is the rail upgrade
http://www.nitrousoutlet.com/catalog...roduct_id=1498
PN 80010-10 is a standard direct port using Pirahna nozzles
RX Speed Works
Jul 24, 2015 02:25 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
