Keep blowing my fuse
Old May 25, 2004 | 06:09 PM
LSUxBlake's Avatar
I have a fuse between the relay and the battery, that one looks fine. I keep blowing the one that powers the switch though, which is the cig. lighter fuse. The whole system will arm, but once I get to the point where the soelonids will kick in, the cig lighter fuse blows and the n20 system dies. Any ideas?
Old May 25, 2004 | 09:02 PM
LSUxBlake's Avatar
I'm wondering if my WOT switch might have the wires switched on it. I say this because earlier I set the window switch to 1000 to test it, and as soon as I armed it, fuel was coming out without the throttle switch being pressed.
Old May 26, 2004 | 10:13 AM
RacinLT1's Avatar
you have something wired up backwards. might be the full throttle switch,and make sure the relay is also wired correctly.
Old May 28, 2004 | 02:56 PM
mike 1978's Avatar
i didn't know you could set up the low end of the window switch that low. (1000) where did you get that pill ?
Old May 28, 2004 | 03:30 PM
LSUxBlake's Avatar
I have a mallory window switch that lets you digitally go between 1000 and 16000 RPM.
Old May 28, 2004 | 03:35 PM
mike 1978's Avatar
my fault, i was thinking MSD RPM switch.
thanks
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
