June Nitrous Specials!!!!
Old Jun 1, 2007 | 11:21 AM
Nitro Dave's Avatar
Ok, Guys it is summer time and June is here. Only a month or tow before it starts getting really hot out. Now is the time to get the car going and at the track before the summer heat sets in.
To help you get your builds going we have put together a few specials for the month of june.. Here they are..
Group 1
Nitrous Outlet LS1/LS2 plate system with 10lb bottle.Your choice of 78mm or 90mm.
Automatic bottle heater
Nitrous pressure guage
Fuel pressure safety switch
NHRA fitting
Blow down tube
Purge kit
Nitrous filter
Digital dual window switch; wide-open-throttle detection, multi-gear lock-out setting, built in TPS, supports low voltage tach signals, works w/ irregular tach signals, push-button programming with integrated LED digital display, Compact rugged, waterproof design.
Also includes (8) NGK TR6 spark plugs.
COST- 1,115.00
Group 2.
Nitrous Outlet 58mm LT1 plate system with 10lb bottle.
NHRA fitting
Blow down tube
Purge kit
Nitrous filter
Image comming soon...
COST-1,115.00
Group 3
(For you Corvette guys)
Dual nozzle dry system.
Nitrous pressure gauge
NHRA fitting
Blow down tube
Automatic Bottle heater
Nitrous Outlet purge kit
Nitrous Filter
Digital dual window switch;wide-open-throttle detection, multi-gear lock-out setting, built in TPS, supports low voltage tach signals, works w/ irregular tach signals, push-button programming with integrated LED digital display, Compact rugged, waterproof design.
NGK TR6 Spark Plugs
Image Comming soon
Cost 820.00
Group 4
(For you GTO Guys)
GTO Halo system
NHRA filtting
Blow down tube
Automatic Bottle Heater
Nitrous Filter
NGK TR6 Spark Plugs
COST- 845.00
Group 5
(For you 98-02 F-body guys)
F-Body Halo system
NHRA filtting
Blow down tube
Nitrous Filter
NGK TR6 Spark Plugs
COST- 845.00
Group 6
(For the Guys running a cone style filter), (GTO & GM TRUCK)
Conical style filter system
NHRA filtting
Blow down tube
Nitrous Filter
NGK TR6 Spark Plugs
Image Comming soon
COST- 845.00
Discounted Items of the month..
Selection 1.
THE BIG SHOW purge system.
If you are looking to make an impression at the start line this is the purge kit for you. Its called THE BIG SHOW FOR A REASON.....
This purge system comes with a large 500hp solenoid, 3 ft of 1/4inch alluminum tubing, purge button and all fittings needed.
With this special we are throwing in a free relay and harness incase you do not already have one.
COST- 95.00
Selection 2
Nitrous Express 10lb bottle
COST=180.00
Selection 3
Zex Bottle Pressure gauge & Manafold
COST-37.00
Selection 4
Nitrous Express Power Booster.
COST-10.00
These specials are good until the end of June.
You can call in your order toll free at 1-866-648-7637
Thank You for your support
Dave
Old Jun 28, 2007 | 10:50 AM
Ray@NitroDaves's Avatar
Bump
karpetcm
Aug 14, 2015 03:02 PM
Aug 7, 2015 08:52 AM
Louey
Pacific
Aug 7, 2015 01:47 AM
Aug 5, 2015 08:35 AM
Aug 3, 2015 08:42 AM
