Jetting on a NOS Plate w/ auxillary fuel pump/cell...
On my plate setup I am looking to spray +/- 175hp. I am not sure where to jet it at being Iwill be using an auxillary low pressure fuel pump on race gas to feed the sustem. Anyone ever done this? Any ideas? Derek
The fuel jet is determined by the pressure you are running. I'm guessing 7ish? The N20 jet is determined by the plate kit you are using so you would have to know the part number.
I would call NOS or one of our sponsors like NitroDaves and ask them for jetting of the kit and the recomended fuel pressure of the kit.
I'm running 1 large fuel cell with 2 fuel systems, 1 for the motor and 1 for the nitrous.
Set your fuel pressure as specified by the manufacturer of your plate. Then use the jets specified for your power level. If your running an NOS Cheater plate that would be 73 for the nitrous and 82 for the fuel. Also, the fuel pressure setting would be 5-6 psi with the system flowing, not static.
Here is the link to the instructions for the NOS Cheater system: http://www.holley.com/data/Products/...A5051-SNOS.pdf
carguyshu
Jan 22, 2017 11:19 AM
