860 heated brackets questions
Old Mar 4, 2007 | 07:44 PM
69z-28's Avatar
is the heater polar or does it not matter what is ground and what is power?
also, what is the draw this thing takes. i need to know if ill be good to splice into the power from the arming switch or if i need a thicker gauge wire.
BTW, im running it off a toggle switch with no sensor or anything, its not automatic.
Old Mar 5, 2007 | 09:15 AM
Ray@NitroDaves's Avatar
I would use a dedicated 12g min wire to run power to the heater...the two wires are not "polar".
The heater draws 240w....it has lower draw due to the better heat transfer properties of the aluminum plate.
Old Mar 5, 2007 | 02:31 PM
69z-28's Avatar
thanks Ray!!! exactly what i wanted to know. + more kudos to Nitrous Outlet.
Jlo
Feb 3, 2015 09:41 PM
Jan 23, 2015 01:13 PM
kandied91z
Jan 23, 2015 11:14 AM
Injuneer
Dec 15, 2014 09:36 AM
Hurin
Dec 13, 2014 07:38 PM
