Ignition ?s
Old Apr 26, 2010 | 01:54 PM
1slo93z's Avatar
Ignition ?s
I have a 93 z28 that has a chip made for hp runs, I put on a 150 shot and now after it gets into 2nd it surges, can this be to much timing? I know I have to retard the timing...If I put in a Mallory 685 can I use that for my nos set up? Its a stock lt1 with a chip, cold air,and a cut out. It does 13.0 on hp and 11.93@110 on spray pulling the left front I'm sure it would do 11.60s if it was'nt surging. I have tr6's @ 35 gap and they still look brand new after the runs also bottle pressure was at 950. PLEASE HELP...
Old May 8, 2010 | 10:19 AM
1slo93z's Avatar
Thanks guys, I got it, all good now all the posts on this helped me out. I just threw more spray at it, and it cleaned right up. 10.08 @ 130 mph bone stock rear end and bone stock lt1....
Old May 8, 2010 | 09:58 PM
slowride94z's Avatar
sarcasm, wins every time
this forum has been slow for a while
I use a 685 for my nitrous, it comes in at 3000 and shuts off at 6000 rpm
the main use of the 685 is to retard my timing @ 2 * for every 50 hp of spray try this
and check your fuel pressure,. what kind of kit do you have dry or wet?
when I had a dry kit on old injectors it seemed to surge, now with a wet kit when you mash the button smiles erupt
Old May 9, 2010 | 03:48 PM
1slo93z's Avatar
Thanks , I have a wet kit and I'm going to try the 685.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Aaront810
Sep 11, 2015 11:24 AM
